14 years ago
Best way to code flop w/asynch reset?
Hi - I've lots of experience in Verilog, but am learning VHDL.
Question: Is this...
process(clk,rst_l) begin
if rst_l = '0' then
sig <= '0';
elsif rising_edge(clk) then
sig <= expression;
end if;
end process;
the best way to do the equivalent of
always @(posedge clk or negedge rst_l) begin
if (!rst_l) sig <= 0;
else begin
sig <= expression;
end
end
(i.e., flop with asynch reset)
I'm asking because in Verilog it's sort of by convention that if you do it -just that way- then all the synthesizers infer you want an asynch flop and the else expression is clocked. I want to make sure I'm doing it the most general way (i.e., least likely for a synth to mis-interpret) for VHDL.
THANKS!
/j
    --- Quote Start ---
    I tend to divide my design in such a way that I get (if possible) small RTL-diagrams with only blocks, and only at the lowest level the logic will become visible. I even code a state machine in its own .vhd file so I can see what the data-flow is, without the state-machine logic cluttering the diagram. So I developed sub-modules for almost every task like counting up or down, multiplexing std_logic_vectors, priority encoders, etc., anything as long as it helps simpliying the RTL-diagram to an easy-to-follow collection of connected blocks.
    --- Quote End ---
    Excellent advice! A man after my own coding style.
    Other arguments for this approach are that you can create testbenches for each submodule, and perform code coverage.
    The other argument for splitting a state machine away from its data path logic (also known as FSM-D, or finite-state-machine data path) is that it is much easier to document. For example, FSMs drawn as algorithmic state machine (ASM) charts map directly to the case and if-then logic of both Verilog and VHDL.
    For examples of ASM charts and block diagrams that are analogous to the RTL diagrams, see:
    http://www.ovro.caltech.edu/~dwh/carma_board/fpga_configuration.pdf
    Cheers,
    Dave
