11 years ago[beginner] D Latch issue
Hi I am new to VHDL programming and I seem to have an issue simulating a D Latch in Quartus II. The main issue is that my code seems to keep transferring input D to output Q when enable E is low(0), even though I do not specify it to do so.
Here is my code:library ieee;use ieee.std_logic_1164.all;
entity lab1 is
port(
signal e: in std_logic;
signal d: in std_logic_vector(3 downto 0);
signal q: out std_logic_vector(3 downto 0));
end lab1;
architecture arc of lab1 is
begin
process(e, d)
begin
if (e = '1') then
q <= d;
end if;
end process;
end arc;
Here is a link to a screencap of my vwf file. It compiles with no errors, but this is the waveform I get, and the output is wrong. (See D transfers to Q on enable 0, which is undesired) http://imgur.com/ydhjqyv
