Basic Functions / Arithmetic is missing in Platform Designer IP Catalog
- 1 year ago
Previous version platform designer arithmetic section only has ALTERA_FP_MATRIX_MULT IP core. Starting from version 20.1std onwards, ALTERA_FP_MATRIX_MULT IP core had been discontinued check this link https://www.intel.com/content/www/us/en/docs/programmable/683750/20-1/about-floating-point-ip-cores.html. Therefore, arithmetic section had been removed.
Sheng
That's odd. I have the Arithmetic group in PD but I'm using the latest Pro with a license, so I'm not sure if this is a Lite vs. Pro difference or you somehow have a bad installation. You may want to try updating to the latest lite edition which I think is 23.1.
You could either build a custom component in PD, adding an Avalon wrapper around the IP created in Quartus itself, or export whatever interfaces you need to connect out of your PD system and instantiate and connect in HDL.
