axi to avalon-MM bridge
I need Bridge kind of thing, which converts axi(slave) to avalon-MM(Master) just like JATG to Avalon MM Bridge IP Catalog is there in Quartus Prime Pro Tool.
If that Bridge is not there then Please can I get any other solution which should helps me to convert axi data into Avalon-MM.
- sstrell
One of the best things about Platform Designer is that you don't always need to manually add a bridge. The interconnect gets built to handle the connection automatically. Just connect your Avalon host (formerly known as a master) to the AXI subordinate (formerly known as a slave) and the interconnect is automatically built for this connection. I believe there is a bridge IP in the IP catalog for this for more control over the connection, but it's not required.
- ShengN_altera
Check this link https://www.intel.com/content/www/us/en/docs/programmable/683609/22-4/bridges-between-and-axi-interfaces.html
As mentioned that, When designing a Platform Designer system, you can make connections between AXI and Avalon® interfaces without the use of explicitly-instantiated bridges; the interconnect provides all necessary bridging logic.
Sheng
