Basavakiran
3 years agoaxi to avalon-MM bridge
Hi, I need Bridge kind of thing, which converts axi(slave) to avalon-MM(Master) just like JATG to Avalon MM Bridge IP Catalog is there in Quartus Prime Pro Tool. If that Bridge is not there the...
ShengN_altera
3 years agoHi,
Check this link https://www.intel.com/content/www/us/en/docs/programmable/683609/22-4/bridges-between-and-axi-interfaces.html
As mentioned that, When designing a Platform Designer system, you can make connections between AXI and Avalon® interfaces without the use of explicitly-instantiated bridges; the interconnect provides all necessary bridging logic.
Sheng
