Basavakiran
3 years agoaxi to avalon-MM bridge
Hi, I need Bridge kind of thing, which converts axi(slave) to avalon-MM(Master) just like JATG to Avalon MM Bridge IP Catalog is there in Quartus Prime Pro Tool. If that Bridge is not there the...
sstrell
3 years agoOne of the best things about Platform Designer is that you don't always need to manually add a bridge. The interconnect gets built to handle the connection automatically. Just connect your Avalon host (formerly known as a master) to the AXI subordinate (formerly known as a slave) and the interconnect is automatically built for this connection. I believe there is a bridge IP in the IP catalog for this for more control over the connection, but it's not required.
