powARman's avatar
powARman
3 years ago
Avalon Verification IP example avlmm_1x1_vhdl not working in Questa Intel FPGA Edition
I encountered some issues with the Avalon-MM BFM we use in simulations after upgrading our project to Quartus 21.1. The BFM is not behaving as expected, accesses to the bus are not finished.
To verify that this is not an issue of our implementation, I tried running the avlmm_1x1_vhdl example from the Avalon Verification IP Suite both in Modelsim Intel FPGA Edition 2020.1 (part of Quartus Standard 20.1) and Questa Intel FPGA Edition 2021.2 (part of Quartus Prime Standard 21.1). I also tried later Quartus Prime versions, but they include the same version of Questa, so there is no difference in using those.
In Modelsim everything works fine, where in Questa the access to the BFM are not finished as expected, the simulation just "hangs" during the second access, see screenshots below. The main difference I see is the master_0/events and slave_0/events signal, which is updating every clock cycle in Modelsim, but is updating much less in Questa.
Is this a known issue of Questa? Is there anything to configure to get around this?
Best regards
Andreas
  • Hi,
    Please follow the debug steps below:
    1.In the run_simulation.tcl script, add this command set USER_DEFINED_ELAB_OPTIONS -novopt to simulate without optimization.
    2.Then, in the command prompt type vsim -suppress 12110 to invoke the Questa simulator GUI.
    3.Then, do run_simulation.tcl script again and should see the full complete simulation.
    Sheng
  • ShengN_altera's avatar
    ShengN_altera
    Sheng
    • powARman's avatar
      powARman
      Hi Sheng,
      I tried it and it works fine now. Thank You
  • IgorKa's avatar
    IgorKa
    Hello.
    The newest revision of QuestaSim does not accept -suppress switch.
    The problem is that the QuestaSim optimizer flashes the delta-events. If you are using multilanguage QuestaSim, the solution is to make little tunning in the "altera_avalon_mm_master_bfm_vhdl_wrapper.sv" file:
    1) Change timescale resolution `timescale 1ps / 1ps
    2) In line 519 add "#1", like:
    always @(mm_master.signal_all_transactions_complete) begin
    events[MM_MSTR_EVENT_ALL_TRANSACTIONS_COMPLETE] = 1;
    #1 events[MM_MSTR_EVENT_ALL_TRANSACTIONS_COMPLETE] <= 0;
    end
    It will solve the problem. You can save the custom file and each Platform Design reconfiguration, just replace the "altera_avalon_mm_master_bfm_vhdl_wrapper.sv" file with a patched one.
    Good Luck
    Igor
    • powARman's avatar
      powARman
      Hello @IgorKa,
      I tried your proposal, I had to add the #1 to all the events to get it working, and I also had to apply the same changes to the slave wrapper file. After doing that, I could run my simulations successfully without having to disable optimizations. Thank you very much.
      I created two sed commands to do the replacement automatically after generating the files:
      sed -i "s/\(^.*timescale 1\)ns\( *\/ *1\)ns\(.*$\)/\1ps\2ps\3/g" avlm_avls_1x1/simulation/submodules/*_wrapper.sv
      sed -i "s/\(^.*\)\(events\[.*\] *<= *0;\)/\1#1 \2/g" avlm_avls_1x1/simulation/submodules/*_wrapper.sv
      Best regards
      Andreas
