11 years agoAssign all zeroes to unsigned
Hi, I want to assign all zeroes to an unsigned signal. I've been using ( others => '0' ) for STD_LOGIC_VECTOR signals, but when i attempt to do the same for unsigned, i get an error:
Error (10500): VHDL syntax error at top.vhd(222) near text "others"; expecting "(", or an identifier ("others" is a reserved keyword), or unary operator Does this only work at the declaration of the signal? Can I use it within my process on reset for example? if not, is there another easy way to set a signal to all zeroes? ( i am trying to avoid typing it all out since I plan to change the size of these signals between subsequent runs. )4 Replies
Unsigned is a base 10 nuber without a sign. So assigning 0 should work.
unsigned_sig <= 0; - Altera_Forum
--- Quote Start --- Unsigned is a base 10 nuber without a sign. So assigning 0 should work. unsigned_sig <= 0; --- Quote End --- You can't do that because 0 is an integer. Also note that unsigned is binary, not base 10. You need to convert to an unsigned from an integer. Op <= to_unsigned(0, op'length); This should also work. Op <= (others => '0'); The ops problem sounds like a syntax error. Why not post the actual code? - Altera_Forum
unsigned type accepts (others => '0');
it also accepts comparing with integer type but not assigning to integer type - Altera_Forum
--- Quote Start --- You can't do that because 0 is an integer. Also note that unsigned is binary, not base 10. You need to convert to an unsigned from an integer. Op <= to_unsigned(0, op'length); This should also work. Op <= (others => '0'); The ops problem sounds like a syntax error. Why not post the actual code? --- Quote End --- Hi, I have no idea what the problem was but i reverted my code to a previous save and made my changes one by one and it worked! i wish i knew what caused the problem in the first place, but i cant even seem to reproduce it now.
