yianchr11
2 years agoArria V DDR3 EMIF toolkit "Unable to establish a connection..."
Hello, I have been trying to debug a DDR3 memory connected to an Arria V 5AGXMA3D4F27I3 device with Quartus prime standard 18.1.0, 18.1.1, 21.1.2 with no success. Using the "DDR3 SDRAM Controller wi...
AdzimZM_Altera
2 years agoHello,
Thank you for submitting your question in Intel Community.
I'm Adzim, will assist you in this thread.
Regarding the error message "Unable to establish a connection because no memory interface targets exist on the linked device", you need to verify that your Quartus project contains the .qsf, .qpf and .sof files in the working directory.
These files are the minimum file set to run EMIF Toolkit.
Have you enabled the debugging option in the EMIF IP?
Adzim
