10 years ago[Arria V] ALTPLL: how to use second counter output
I'm still new in using the Quartus II software. May I know how to select/use the second counter output for pll from the Megawizard Plug-In Manager? Prompt reply from you guys would be greatly helpful. Thanks!5 Replies
There is a check-box "use this clock" that you must select to enable the second (or 3rd/4th etc.) output.
Cheers, Alex - Altera_Forum
--- Quote Start --- There is a check-box "use this clock" that you must select to enable the second (or 3rd/4th etc.) output. Cheers, Alex --- Quote End --- I'm sorry but in which tab is the check-box? I'm using version 15.1 by the way... And may I know whether the "Output Clock" in the General tab is consider as the counter output? Thanks! - Altera_Forum
Under the tab "3) output clocks" => select "clk c1" => "use this clock". Tick this box
https://www.alteraforum.com/forum/attachment.php?attachmentid=12005 Cheers, Alex - Altera_Forum
Hi Alex,
I think they've change the Megawizard GUI in 15.1. Am assuming c0 = outclk0, c1 = outclk1 and so on... https://www.alteraforum.com/forum/attachment.php?attachmentid=12015 - Altera_Forum
Indeed, different GUIs for different families (I hadn't spotted Arria V in your tittle).
Under 'output clocks', use the drop down menu next to 'number of clocks'. Select how many you want. Cheers, Alex
