10 years ago[Arria V] ALTPLL: how to use second counter output
Hi, I'm still new in using the Quartus II software. May I know how to select/use the second counter output for pll from the Megawizard Plug-In Manager? Prompt reply from you guys would be g...
10 years agoIndeed, different GUIs for different families (I hadn't spotted Arria V in your tittle).
Under 'output clocks', use the drop down menu next to 'number of clocks'. Select how many you want. Cheers, Alex
