10 years ago[Arria V] ALTPLL: how to use second counter output
Hi, I'm still new in using the Quartus II software. May I know how to select/use the second counter output for pll from the Megawizard Plug-In Manager? Prompt reply from you guys would be g...
10 years ago --- Quote Start --- There is a check-box "use this clock" that you must select to enable the second (or 3rd/4th etc.) output. Cheers, Alex --- Quote End --- I'm sorry but in which tab is the check-box? I'm using version 15.1 by the way... And may I know whether the "Output Clock" in the General tab is consider as the counter output? Thanks!
