ARRIA 10GX doesn't show in lspci
Hello everybody!
During installation process I've performed all necessary steps till this one: https://www.intel.com/content/www/us/en/programmable/documentation/tgy1490191698959.html#wmh1490212984610 After I've completed soft reboot there is no Altera device in lspci.
Also dmesg shows next:
aclpci_a10_ref_drv: loading out-of-tree module taints kernel.
aclpci_a10_ref_drv: module verification failed: signature and/or required key missing - tainting kernel
I would really appreciate any help and ready to provide details about system.
- KhaiChein_Y_Intel
Hi YSika2, Could you check if this link helps: https://forums.intel.com/s/question/0D50P000045gnGdSAI/aocl-program-and-aocl-diagnose-commands-fail?language=en_US Thanks- YSika2
Hello KYeoh!
I blacklisted them in /etc/modprobe.d/blacklist.conf
No effect.
I should mention that I plugged FPGA not into PCIe 3 x8 bun itno PCIe 3 x16. Not sure that this could cause some problems but who knows.
Yehor
- YSika2
Hello KYeoh!
No effect.
Yehor
- KhaiChein_Y_Intel
Hi YSika2, Could you provide the following information? 1. BSP version 2. OS 3. Kernel version 4. result of aocl install Thanks.- YSika2
Thanks for answer but now problem is resolved.
Simply I replaced one host machine by another. And now not able to provide necessary info.
Yehor
- YSika2
But seems like I still need your help.
Till 'aocl flash acl0 boardtest.aocx' I faced an error:
Device not part of know packages.
Warning:
No devices attached for package:
/home/USERNAME/intelFPGA_pro/18.1/hld/board/a10_ref
I've tried to set JtagClock to 6M and install packages before programming flash.
- BSP version - a10_ref
- OS - Ubuntu 16.04.5 LTS
- Kernel - 4.15.0-43-generic
- aocl install produces next:
Do you want to install /home/USERNAME/intelFPGA_pro/18.1/hld/board/a10_ref? [y/n] y
aocl install: Adding the board package /home/USERNAME/intelFPGA_pro/18.1/hld/board/a10_ref to the list of installed pckages
aocl install: Setting up FCD
aocl install: Running install from /home/USERNAME/intelFPGA_pro/18.1/hld/board/a10_ref/linux64/libexec
Looking for kernel source files in /lib/modules/4.15.0-43-generic/build
Using kernel source files from /lib/modules/4.15.0-43-generic/build
Building driver for BSP with name a10_ref
make: Entering directory '/usr/src/linux-headers-4.15.0-43-generic'
CC [M] /tmp/opencl_driver_P8ktFJ/aclpci_queue.o
CC [M] /tmp/opencl_driver_P8ktFJ/aclpci.o
CC [M] /tmp/opencl_driver_P8ktFJ/aclpci_fileio.o
CC [M] /tmp/opencl_driver_P8ktFJ/aclpci_dma.o
CC [M] /tmp/opencl_driver_P8ktFJ/aclpci_pr.o
CC [M] /tmp/opencl_driver_P8ktFJ/aclpci_cmd.o
LD [M] /tmp/opencl_driver_P8ktFJ/aclpci_a10_ref_drv.o
Building modules, stage 2.
MODPOST 1 modules
CC /tmp/opencl_driver_P8ktFJ/aclpci_a10_ref_drv.mod.o
LD [M] /tmp/opencl_driver_P8ktFJ/aclpci_a10_ref_drv.ko
make: Leaving directory '/usr/src/linux-headers-4.15.0-43-generic'
Yehor
- KhaiChein_Y_Intel
Hi YSika2,
What is the software edition(Pro/Standard) and version you are using? Is it v18.1?
Can you share the result of aocl diagnose and the steps taken?
- YSika2
I am using Pro edition v18.1.
aocl diagnose -------------------------------------------------------------------- Warning: No devices attached for package: /home/USERNAME/intelFPGA_pro/18.1/hld/board/a10_ref -------------------------------------------------------------------- Vendor: Intel(R) Corporation Found no active device installed on the host machine. Please make sure to: 1. Set the environment variable AOCL_BOARD_PACKAGE_ROOT to the correct board package. 2. Install the driver from the selected board package. 3. Properly install the device in the host machine. 4. Configure the device with a supported OpenCL design. 5. Reboot the machine if the PCI Express link failed. DIAGNOSTIC_FAILED -------------------------------------------------------------------- Call "aocl diagnose <device-names>" to run diagnose for specified devices Call "aocl diagnose all" to run diagnose for all devices aocl diagnose all return nothing quartus_pgm -l Info: ******************************************************************* Info: Running Quartus Prime Programmer Info: Version 18.1.0 Build 222 09/21/2018 SJ Pro Edition Info: Copyright (C) 2018 Intel Corporation. All rights reserved. Info: Your use of Intel Corporation's design tools, logic functions Info: and other software and tools, and its AMPP partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Intel Program License Info: Subscription Agreement, the Intel Quartus Prime License Agreement, Info: the Intel FPGA IP License Agreement, or other applicable license Info: agreement, including, without limitation, that your use is for Info: the sole purpose of programming logic devices manufactured by Info: Intel and sold by Intel or its authorized distributors. Please Info: refer to the applicable agreement for further details. Info: Processing started: Mon Jan 28 15:17:12 2019 Info: Command: quartus_pgm -l 1) USB-BlasterII [2-1.2] Info: Quartus Prime Programmer was successful. 0 errors, 0 warnings Info: Peak virtual memory: 736 megabytes Info: Processing ended: Mon Jan 28 15:17:12 2019 Info: Elapsed time: 00:00:00 jtagconfig 1) USB-BlasterII [2-1.2] 02E660DD 10AX115H1(.|E2|ES)/10AX115H2/.. 020A40DD 5M(1270ZF324|2210Z)/EPM2210 quartus_pgm -c 1 -m JTAG -o "p;/home/USERNAME/Downloads/max5_150.pof@2" Info: ******************************************************************* Info: Running Quartus Prime Programmer Info: Version 18.1.0 Build 222 09/21/2018 SJ Pro Edition Info: Copyright (C) 2018 Intel Corporation. All rights reserved. Info: Your use of Intel Corporation's design tools, logic functions Info: and other software and tools, and its AMPP partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Intel Program License Info: Subscription Agreement, the Intel Quartus Prime License Agreement, Info: the Intel FPGA IP License Agreement, or other applicable license Info: agreement, including, without limitation, that your use is for Info: the sole purpose of programming logic devices manufactured by Info: Intel and sold by Intel or its authorized distributors. Please Info: refer to the applicable agreement for further details. Info: Processing started: Mon Jan 28 15:21:32 2019 Info: Command: quartus_pgm -c 1 -m JTAG -o p;/home/USERNAME/Downloads/max5_150.pof@2 Info (213045): Using programming cable "USB-BlasterII [2-1.2]" Info (213011): Using programming file /home/USERNAME/Downloads/max5_150.pof with checksum 0x00908D89 for device 5M2210ZF256@2 Info (209060): Started Programmer operation at Mon Jan 28 15:21:33 2019 Info (209017): Device 2 contains JTAG ID code 0x020A40DD Info (209018): Device 2 silicon ID is ALTERA10-6 Info (209044): Erasing MAXII/MAXV configuration device(s) Info (209023): Programming device(s) Info (209021): Performing verification on device(s) Info (209011): Successfully performed operation(s) Info (209061): Ended Programmer operation at Mon Jan 28 15:21:41 2019 Info: Quartus Prime Programmer was successful. 0 errors, 0 warnings Info: Peak virtual memory: 899 megabytes Info: Processing ended: Mon Jan 28 15:21:41 2019 Info: Elapsed time: 00:00:09 quartus_pgm -c 1 -m JTAG -o "p;/home/USERNAME/Downloads/top.sof" Info: ******************************************************************* Info: Running Quartus Prime Programmer Info: Version 18.1.0 Build 222 09/21/2018 SJ Pro Edition Info: Copyright (C) 2018 Intel Corporation. All rights reserved. Info: Your use of Intel Corporation's design tools, logic functions Info: and other software and tools, and its AMPP partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Intel Program License Info: Subscription Agreement, the Intel Quartus Prime License Agreement, Info: the Intel FPGA IP License Agreement, or other applicable license Info: agreement, including, without limitation, that your use is for Info: the sole purpose of programming logic devices manufactured by Info: Intel and sold by Intel or its authorized distributors. Please Info: refer to the applicable agreement for further details. Info: Processing started: Mon Jan 28 15:22:36 2019 Info: Command: quartus_pgm -c 1 -m JTAG -o p;/home/USERNAME/Downloads/top.sof Info (213045): Using programming cable "USB-BlasterII [2-1.2]" Info (213011): Using programming file /home/USERNAME/Downloads/top.sof with checksum 0x308B210D for device 10AX115S2F45@1 Info (209060): Started Programmer operation at Mon Jan 28 15:22:43 2019 Info (209016): Configuring device index 1 Info (209017): Device 1 contains JTAG ID code 0x02E660DD Info (209007): Configuration succeeded -- 1 device(s) configured Info (209011): Successfully performed operation(s) Info (209061): Ended Programmer operation at Mon Jan 28 15:22:58 2019 Info: Quartus Prime Programmer was successful. 0 errors, 0 warnings Info: Peak virtual memory: 2338 megabytes Info: Processing ended: Mon Jan 28 15:22:58 2019 Info: Elapsed time: 00:00:22 jtagconfig --getparam 1 JtagClock 6MRegards,
Yehor
- KhaiChein_Y_Intel
Hi YSika2,
What is the output of lspci -v?
- KhaiChein_Y_Intel
Hi YSika2, Any updates? Thanks- YSika2
I need to use FPGA with OpenVino toolkit so I just switched tutorial to this one https://software.intel.com/en-us/articles/OpenVINO-Install-Linux-FPGA . After this everything works properly
- YSika2
Hello. I need to use FPGA with OpenVino. I've just switched to another tutorial https://software.intel.com/en-us/articles/OpenVINO-Install-Linux-FPGA and everything work properly.
