ARRIA 10GX doesn't show in lspci
- YSika27 years ago
Thanks for answer but now problem is resolved.
Simply I replaced one host machine by another. And now not able to provide necessary info.
Yehor
- YSika27 years ago
But seems like I still need your help.
Till 'aocl flash acl0 boardtest.aocx' I faced an error:
Device not part of know packages.
Warning:
No devices attached for package:
/home/USERNAME/intelFPGA_pro/18.1/hld/board/a10_ref
I've tried to set JtagClock to 6M and install packages before programming flash.
- BSP version - a10_ref
- OS - Ubuntu 16.04.5 LTS
- Kernel - 4.15.0-43-generic
- aocl install produces next:
Do you want to install /home/USERNAME/intelFPGA_pro/18.1/hld/board/a10_ref? [y/n] y
aocl install: Adding the board package /home/USERNAME/intelFPGA_pro/18.1/hld/board/a10_ref to the list of installed pckages
aocl install: Setting up FCD
aocl install: Running install from /home/USERNAME/intelFPGA_pro/18.1/hld/board/a10_ref/linux64/libexec
Looking for kernel source files in /lib/modules/4.15.0-43-generic/build
Using kernel source files from /lib/modules/4.15.0-43-generic/build
Building driver for BSP with name a10_ref
make: Entering directory '/usr/src/linux-headers-4.15.0-43-generic'
CC [M] /tmp/opencl_driver_P8ktFJ/aclpci_queue.o
CC [M] /tmp/opencl_driver_P8ktFJ/aclpci.o
CC [M] /tmp/opencl_driver_P8ktFJ/aclpci_fileio.o
CC [M] /tmp/opencl_driver_P8ktFJ/aclpci_dma.o
CC [M] /tmp/opencl_driver_P8ktFJ/aclpci_pr.o
CC [M] /tmp/opencl_driver_P8ktFJ/aclpci_cmd.o
LD [M] /tmp/opencl_driver_P8ktFJ/aclpci_a10_ref_drv.o
Building modules, stage 2.
MODPOST 1 modules
CC /tmp/opencl_driver_P8ktFJ/aclpci_a10_ref_drv.mod.o
LD [M] /tmp/opencl_driver_P8ktFJ/aclpci_a10_ref_drv.ko
make: Leaving directory '/usr/src/linux-headers-4.15.0-43-generic'
Yehor
