YSika2
7 years agoARRIA 10GX doesn't show in lspci
Hello everybody! During installation process I've performed all necessary steps till this one: https://www.intel.com/content/www/us/en/programmable/documentation/tgy1490191698959.html#wmh14902129846...
KhaiChein_Y_Intel
7 years agoHi YSika2,
What is the software edition(Pro/Standard) and version you are using? Is it v18.1?
Can you share the result of aocl diagnose and the steps taken?
- YSika27 years ago
I am using Pro edition v18.1.
aocl diagnose -------------------------------------------------------------------- Warning: No devices attached for package: /home/USERNAME/intelFPGA_pro/18.1/hld/board/a10_ref -------------------------------------------------------------------- Vendor: Intel(R) Corporation Found no active device installed on the host machine. Please make sure to: 1. Set the environment variable AOCL_BOARD_PACKAGE_ROOT to the correct board package. 2. Install the driver from the selected board package. 3. Properly install the device in the host machine. 4. Configure the device with a supported OpenCL design. 5. Reboot the machine if the PCI Express link failed. DIAGNOSTIC_FAILED -------------------------------------------------------------------- Call "aocl diagnose <device-names>" to run diagnose for specified devices Call "aocl diagnose all" to run diagnose for all devices aocl diagnose all return nothing quartus_pgm -l Info: ******************************************************************* Info: Running Quartus Prime Programmer Info: Version 18.1.0 Build 222 09/21/2018 SJ Pro Edition Info: Copyright (C) 2018 Intel Corporation. All rights reserved. Info: Your use of Intel Corporation's design tools, logic functions Info: and other software and tools, and its AMPP partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Intel Program License Info: Subscription Agreement, the Intel Quartus Prime License Agreement, Info: the Intel FPGA IP License Agreement, or other applicable license Info: agreement, including, without limitation, that your use is for Info: the sole purpose of programming logic devices manufactured by Info: Intel and sold by Intel or its authorized distributors. Please Info: refer to the applicable agreement for further details. Info: Processing started: Mon Jan 28 15:17:12 2019 Info: Command: quartus_pgm -l 1) USB-BlasterII [2-1.2] Info: Quartus Prime Programmer was successful. 0 errors, 0 warnings Info: Peak virtual memory: 736 megabytes Info: Processing ended: Mon Jan 28 15:17:12 2019 Info: Elapsed time: 00:00:00 jtagconfig 1) USB-BlasterII [2-1.2] 02E660DD 10AX115H1(.|E2|ES)/10AX115H2/.. 020A40DD 5M(1270ZF324|2210Z)/EPM2210 quartus_pgm -c 1 -m JTAG -o "p;/home/USERNAME/Downloads/max5_150.pof@2" Info: ******************************************************************* Info: Running Quartus Prime Programmer Info: Version 18.1.0 Build 222 09/21/2018 SJ Pro Edition Info: Copyright (C) 2018 Intel Corporation. All rights reserved. Info: Your use of Intel Corporation's design tools, logic functions Info: and other software and tools, and its AMPP partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Intel Program License Info: Subscription Agreement, the Intel Quartus Prime License Agreement, Info: the Intel FPGA IP License Agreement, or other applicable license Info: agreement, including, without limitation, that your use is for Info: the sole purpose of programming logic devices manufactured by Info: Intel and sold by Intel or its authorized distributors. Please Info: refer to the applicable agreement for further details. Info: Processing started: Mon Jan 28 15:21:32 2019 Info: Command: quartus_pgm -c 1 -m JTAG -o p;/home/USERNAME/Downloads/max5_150.pof@2 Info (213045): Using programming cable "USB-BlasterII [2-1.2]" Info (213011): Using programming file /home/USERNAME/Downloads/max5_150.pof with checksum 0x00908D89 for device 5M2210ZF256@2 Info (209060): Started Programmer operation at Mon Jan 28 15:21:33 2019 Info (209017): Device 2 contains JTAG ID code 0x020A40DD Info (209018): Device 2 silicon ID is ALTERA10-6 Info (209044): Erasing MAXII/MAXV configuration device(s) Info (209023): Programming device(s) Info (209021): Performing verification on device(s) Info (209011): Successfully performed operation(s) Info (209061): Ended Programmer operation at Mon Jan 28 15:21:41 2019 Info: Quartus Prime Programmer was successful. 0 errors, 0 warnings Info: Peak virtual memory: 899 megabytes Info: Processing ended: Mon Jan 28 15:21:41 2019 Info: Elapsed time: 00:00:09 quartus_pgm -c 1 -m JTAG -o "p;/home/USERNAME/Downloads/top.sof" Info: ******************************************************************* Info: Running Quartus Prime Programmer Info: Version 18.1.0 Build 222 09/21/2018 SJ Pro Edition Info: Copyright (C) 2018 Intel Corporation. All rights reserved. Info: Your use of Intel Corporation's design tools, logic functions Info: and other software and tools, and its AMPP partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Intel Program License Info: Subscription Agreement, the Intel Quartus Prime License Agreement, Info: the Intel FPGA IP License Agreement, or other applicable license Info: agreement, including, without limitation, that your use is for Info: the sole purpose of programming logic devices manufactured by Info: Intel and sold by Intel or its authorized distributors. Please Info: refer to the applicable agreement for further details. Info: Processing started: Mon Jan 28 15:22:36 2019 Info: Command: quartus_pgm -c 1 -m JTAG -o p;/home/USERNAME/Downloads/top.sof Info (213045): Using programming cable "USB-BlasterII [2-1.2]" Info (213011): Using programming file /home/USERNAME/Downloads/top.sof with checksum 0x308B210D for device 10AX115S2F45@1 Info (209060): Started Programmer operation at Mon Jan 28 15:22:43 2019 Info (209016): Configuring device index 1 Info (209017): Device 1 contains JTAG ID code 0x02E660DD Info (209007): Configuration succeeded -- 1 device(s) configured Info (209011): Successfully performed operation(s) Info (209061): Ended Programmer operation at Mon Jan 28 15:22:58 2019 Info: Quartus Prime Programmer was successful. 0 errors, 0 warnings Info: Peak virtual memory: 2338 megabytes Info: Processing ended: Mon Jan 28 15:22:58 2019 Info: Elapsed time: 00:00:22 jtagconfig --getparam 1 JtagClock 6MRegards,
Yehor
