YSika2
7 years agoARRIA 10GX doesn't show in lspci
Hello everybody! During installation process I've performed all necessary steps till this one: https://www.intel.com/content/www/us/en/programmable/documentation/tgy1490191698959.html#wmh14902129846...
KhaiChein_Y_Intel
7 years agoHi YSika2,
What is the software edition(Pro/Standard) and version you are using? Is it v18.1?
Can you share the result of aocl diagnose and the steps taken?
YSika2
7 years agoI am using Pro edition v18.1.
aocl diagnose
Warning:
No devices attached for package:
/home/USERNAME/intelFPGA_pro/18.1/hld/board/a10_ref
Vendor: Intel(R) Corporation
Found no active device installed on the host machine.
Please make sure to:
1. Set the environment variable AOCL_BOARD_PACKAGE_ROOT to the correct board package.
2. Install the driver from the selected board package.
3. Properly install the device in the host machine.
4. Configure the device with a supported OpenCL design.
5. Reboot the machine if the PCI Express link failed.
DIAGNOSTIC_FAILED
Call "aocl diagnose <device-names>" to run diagnose for specified devices
Call "aocl diagnose all" to run diagnose for all devices
aocl diagnose all return nothing
quartus_pgm -l
Info: *******************************************************************
Info: Running Quartus Prime Programmer
Info: Version 18.1.0 Build 222 09/21/2018 SJ Pro Edition
Info: Copyright (C) 2018 Intel Corporation. All rights reserved.
Info: Your use of Intel Corporation's design tools, logic functions
Info: and other software and tools, and its AMPP partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Intel Program License
Info: Subscription Agreement, the Intel Quartus Prime License Agreement,
Info: the Intel FPGA IP License Agreement, or other applicable license
Info: agreement, including, without limitation, that your use is for
Info: the sole purpose of programming logic devices manufactured by
Info: Intel and sold by Intel or its authorized distributors. Please
Info: refer to the applicable agreement for further details.
Info: Processing started: Mon Jan 28 15:17:12 2019
Info: Command: quartus_pgm -l
1) USB-BlasterII [2-1.2]
Info: Quartus Prime Programmer was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 736 megabytes
Info: Processing ended: Mon Jan 28 15:17:12 2019
Info: Elapsed time: 00:00:00
jtagconfig
02E660DD 10AX115H1(.|E2|ES)/10AX115H2/..
020A40DD 5M(1270ZF324|2210Z)/EPM2210
quartus_pgm -c 1 -m JTAG -o "p;/home/USERNAME/Downloads/max5_150.pof@2"
Info: Processing started: Mon Jan 28 15:21:32 2019
Info: Command: quartus_pgm -c 1 -m JTAG -o p;/home/USERNAME/Downloads/max5_150.pof@2
Info (213045): Using programming cable "USB-BlasterII [2-1.2]"
Info (213011): Using programming file /home/USERNAME/Downloads/max5_150.pof with checksum 0x00908D89 for device 5M2210ZF256@2
Info (209060): Started Programmer operation at Mon Jan 28 15:21:33 2019
Info (209017): Device 2 contains JTAG ID code 0x020A40DD
Info (209018): Device 2 silicon ID is ALTERA10-6
Info (209044): Erasing MAXII/MAXV configuration device(s)
Info (209023): Programming device(s)
Info (209021): Performing verification on device(s)
Info (209011): Successfully performed operation(s)
Info (209061): Ended Programmer operation at Mon Jan 28 15:21:41 2019
Info: Peak virtual memory: 899 megabytes
Info: Processing ended: Mon Jan 28 15:21:41 2019
Info: Elapsed time: 00:00:09
quartus_pgm -c 1 -m JTAG -o "p;/home/USERNAME/Downloads/top.sof"
Info: Processing started: Mon Jan 28 15:22:36 2019
Info: Command: quartus_pgm -c 1 -m JTAG -o p;/home/USERNAME/Downloads/top.sof
Info (213011): Using programming file /home/USERNAME/Downloads/top.sof with checksum 0x308B210D for device 10AX115S2F45@1
Info (209060): Started Programmer operation at Mon Jan 28 15:22:43 2019
Info (209016): Configuring device index 1
Info (209017): Device 1 contains JTAG ID code 0x02E660DD
Info (209007): Configuration succeeded -- 1 device(s) configured
Info (209061): Ended Programmer operation at Mon Jan 28 15:22:58 2019
Info: Peak virtual memory: 2338 megabytes
Info: Processing ended: Mon Jan 28 15:22:58 2019
Info: Elapsed time: 00:00:22
jtagconfig --getparam 1 JtagClock
6MRegards,
Yehor
