skyjuice88
2 years agoArria 10 Not Found in Project Wizard
I have installed Arria10 on Quartus Pro 23.4 (see below), but when I am setting a new project using the wizard, Arria 10 is not available from the drop-down Device Family menu. Only Cyclone 10 is the...
RichardT_altera
2 years agoWhich OS system are you using?
Could you try to install in a different machine and see if the issue persist?
I am able to select Arria10 device with Quartus Pro 23.1 (with Arria 10 and Cyclone 10 GX installed), in Window 10, with eval license.
Richard Tan
