cconger
7 years agoArria 10 GX PLL not producing correct phase shift
I have generated an Altera PLL using Quartus Prime Standard Edition 17.1. The PLL accepts a 50 MHz reference clock, and produces five output clocks: 50 MHz, 200 MHz, 200 MHz w/ 1250ps shift, 333 MH...
JonWay_altera
7 years agoHi @CCong1
Tested on QII v18.1std and Modelsim 10.6d.
It seemed to work fine.
I used your Qsys file, wrap it with a top file, recompiled and simulated it. I attached the folder.
To simulate, open up Modelsim. Go to <unzipped path>/simulation/modelsim
Run: do pllforum_run_msim_rtl_verilog.do
It should show as screenshot.
You will see outclk3 and outclk4 are shifted by 1250ps as expected.
