12 years ago
Array en VHDL
Hi everybody !
I want to add(xor) data with CD in shape array and the result would be S
Can you help me correcting this code :
library ieee;use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity cdm is
port (
         clk : in std_logic ;
         rst : in std_logic  ;
         data: in std_logic  ;
        odata: out std_logic  ;
         CD  : in  std_logic_vector(15 downto 0) ;
        isis :out  integer range 0 to 3  ;
         S   :out std_logic_vector(3 downto 0 ));
end entity ;
architecture beh of cdm is
    type tab is array(3 downto 0)of std_logic_vector(15 downto 0);
        signal i      :integer range 0 to 3 ;
        signal idata  :std_logic  ;
        signal itab :tab ;
        begin
         code :process(clk,rst)
               begin
                    if(rst='1')then
                     itab(i)<="0000" ;
                    else
                        if(clk'event and clk='1')then
                           itab(i)<= not(CD(15 downto 12)xor (data));
                           S(i)<=itab(i);
                           i<= i+1 ;
                           itab(i)<=not(CD (11 downto 8) xor(data));
                            S(i)<=itab(i);
                            i<=i+1 ;
                           itab(i)<=not( CD(7 downto 4) xor (data));
                            S(i)<=itab(i);
                            i<=i+1;
                           itab(i)<=not( CD(3 downto 0) xor (data));
                            S(i)<=itab(i);
                            i<=i+1 ;
                           if i=3 then
                                 idata<=data ;
                            end if ;
                          end if ;
                       end if ;
                  end process ;
                  isis<=i;
                 odata<=idata ;
   end architecture ;
Thank you in advance for your answer
    is that error in this file or another? also as a sidenote, putting your code in code tags improves readability.
    hi guys !!
    i solved my problem but i have another is near of ""Type Re is array ""
    can you help me please !!
    library ieee;
    entity cdma_testbipo is
    port (
    type Re is array(0 to 3)of integer range 0 to 15;
    signal CD: Re ;
    S :out integer range -8 to 7 );
    end entity ;
    architecture beh of cdma_testbipo is
    type RAM is array (0 to 3) of integer range -8 to 7;
    signal code : RAM;
    begin
    code(0)<=CD(15 downto 12);
    code(1)<=CD(11 downto 8) ;
    code(2)<=CD(7 downto 4) ;
    code(3)<=CD(3 downto 0) ;
    bpsk :process(clk,rst)
    begin
    if(rst='1')then
    i<= 0;
    else
    i<=i+1 ;
    if(idata='0') then
    s<=-code(i);
    else
    s<=code(i);
    end if;
    if(i=3) then
    idata<=data;
    end if;
    end if ;
    end if ;
    end process ;
    isis<=i;
    odata<=idata ;
    end architecture ;
    Thank you
    you cannot declare an array type inside a port declaration. It will need to be in a package
