hi guys !!
i solved my problem but i have another is near of ""Type Re is array ""
can you help me please !!
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity cdma_testbipo is
port (
clk : in std_logic ;
rst : in std_logic ;
data: in std_logic ;
odata: out std_logic ;
type Re is array(0 to 3)of integer range 0 to 15;
signal CD: Re ;
isis :out integer range 0 to 3 ;
S :out integer range -8 to 7 );
end entity ;
architecture beh of cdma_testbipo is
type RAM is array (0 to 3) of integer range -8 to 7;
signal i :integer range 0 to 3 ;
signal code : RAM;
signal idata :std_logic ;
begin
code(0)<=CD(15 downto 12);
code(1)<=CD(11 downto 8) ;
code(2)<=CD(7 downto 4) ;
code(3)<=CD(3 downto 0) ;
bpsk :process(clk,rst)
begin
if(rst='1')then
i<= 0;
else
if(clk'event and clk='1')then
i<=i+1 ;
if(idata='0') then
s<=-code(i);
else
s<=code(i);
end if;
if(i=3) then
idata<=data;
end if;
end if ;
end if ;
end process ;
isis<=i;
odata<=idata ;
end architecture ;
Thank you
