14 years agoRysc I believe I have a few hundreds of files, so it is quite a tedious job, even worse, if I use the same libraries in several projects, I'll have to do it all over again. the .qip will solve that problem, just add one file (instead of adding the library.
you are correct that I use the term library in the "search path" sense, not VHDL sense.
