14 years agoAnalysis & Synthesis, Fitter Warnings
I'm currently cleaning up my design, reducing and explaining as many of the remaining warnings as possible. However for the following warnings, I have no clue so far. Any explanation would be of great help...
analysis & synthesis: Warning: Ignored DEDICATED_MULTIPLIER_CIRCUITRY parameter with setting "AUTO" for node "PROC:\P:0:PRC|...|altmult_add:altmult_add_component|mult_add_tsb3:auto_generated|mac_out5" Actually "AUTO" seems the setting with most freedom to me. What is it "ignored" and what's the impact? And the reason? From the fitter report, I learn that 4 DSP elements are used, as for similar (parallel) instances PROC:\P:1:PRC|... and PROC:\P:2:PRC|... which don't show the warning. fitter: There are a number of "ignored assignments" types, which I don't understand: Name I.E. Ignored To Ignored Value Ignored Source I/O Standard termination_blk0~r.._pad 1.8 V QSF Assignment Global signal 1) sc_clk_dp[.] off Compiler or HDL Assignment Sync. Ident. 2) reset_reg[.] FORCED_IF_ASYNCHRONOUS Compiler or HDL Assignment 1) M_phy_alt_mem_phy_seq_wrapper 2) alt_ddrx_reset_sync What's happening here?
