Analysis & Synthesis Error(13224): Verilog HDL or VHDL error "..:" index -8 is out of range [15:0]..
Hi @Ranesh ,
The reason for the error is the value of parameter W_MODULE_DATA (256) in submodule vector_capture.sv being overridden by the value of parameter W_MODULE_DATA (16) in top-module vector_capture_synth_top.sv.
Sheng
Hi Sheng,
Thank you for your answer.
What you are saying is correct, but that cannot be the reason for this error message.
From lines 26 and 27 of vector_capture_synth.sv
26: parameter W_MODULE_DATA = 16; // Supported data widths (8 bits to 256 bits) power of 2 (2^3 to 2^8)
27: parameter W_MODULE_DESC = 204; // less than or equal to 256
From lines 66 to 70 of vector_capture.sv are:
66: localparam c_DESCBYTEALIGNBITS = ((W_MODULE_DESC %
c_DESCBYTEALIGNBITS = ((204 %
c_DESCBYTEALIGNBITS = 4
67: logic [((W_MODULE_DESC + c_DESCBYTEALIGNBITS) - 1):0] s_in_desc; // Configuration bus from feeder module
logic [((204 + 4) -1):0] s_in_des
logic [207:0] s_in_des
68: localparam c_IN_DESC_BYTE_CNT = ((W_MODULE_DESC + c_DESCBYTEALIGNBITS)/8);
c_IN_DESC_BYTE_CNT = ((204 + 4)/8)
c_IN_DESC_BYTE_CNT = ((208)/8)
c_IN_DESC_BYTE_CNT = 26
69: localparam c_IN_DATA_BYTE_CNT = (W_MODULE_DATA/8);
c_IN_DATA_BYTE_CNT = (16/8)
c_IN_DATA_BYTE_CNT = 2
70: localparam c_OUT_DATA_BYTE_CNT = (W_MCDMA_DATA/8);
c_OUT_DATA_BYTE_CNT = (256/8)
c_OUT_DATA_BYTE_CNT = 32
The lines 140 and 144 are in vector_capture.sv are:
140: for (int c = c_IN_DESC_BYTE_CNT; c < c_OUT_DATA_BYTE_CNT; c++)
(int c = 26; c < 32; c++)
c can take only 26, 27, 28, 29, 30 and 31
141: begin
142: if (c < (c_IN_DESC_BYTE_CNT + (c_IN_DATA_BYTE_CNT - s_in_empty)))
(c < (26 + (2 - s_in_empty)))
(c < (28 - s_in_empty))
if s_in_empty is 0
c can take only 26 and 27
if s_in_empty is 1
c can take only 26
143: s_output_data[c] <= s_in_data[((W_MODULE_DATA - ((c - c_IN_DESC_BYTE_CNT) * 8)) - 1) -: 8];
If c become 26, the line becomes
s_output_data[26] <= s_in_data[((16 - ((26 - 26) * 8)) - 1) -: 8]
s_output_data[26] <= s_in_data[((16 - ((0) * 8)) - 1) -: 8]
s_output_data[26] <= s_in_data[((16 - 0 - 1) -: 8]
s_output_data[26] <= s_in_data[15 -: 8]
s_output_data[26] <= s_in_data[15 : 8]
If c become 27, the line becomes
s_output_data[27] <= s_in_data[((16 - ((27 - 26) * 8)) - 1) -: 8]
s_output_data[27] <= s_in_data[((16 - ((1) * 8)) - 1) -: 8]
s_output_data[27] <= s_in_data[((16 - 8 - 1) -: 8]
s_output_data[27] <= s_in_data[7 -: 8]
s_output_data[27] <= s_in_data[7 : 0]
144: end
From the above calculations, c cannot take any values that drives the index of s_in_data to be -8.
Ranesh
