Analysis & Synthesis Error(13224): Verilog HDL or VHDL error "..:" index -8 is out of range [15:0]..
Hi @Ranesh ,
The reason for the error is the value of parameter W_MODULE_DATA (256) in submodule vector_capture.sv being overridden by the value of parameter W_MODULE_DATA (16) in top-module vector_capture_synth_top.sv.
Sheng
- Ranesh3 years ago
Hi Sheng,
Thank you for your answer.
What you are saying is correct, but that cannot be the reason for this error message.
From lines 26 and 27 of vector_capture_synth.sv
26: parameter W_MODULE_DATA = 16; // Supported data widths (8 bits to 256 bits) power of 2 (2^3 to 2^8)
27: parameter W_MODULE_DESC = 204; // less than or equal to 256From lines 66 to 70 of vector_capture.sv are:
66: localparam c_DESCBYTEALIGNBITS = ((W_MODULE_DESC %
> 0) ? (8 - (W_MODULE_DESC % 8)) : 3'b0; c_DESCBYTEALIGNBITS = ((204 %
> 0) ? (8 - (204 % 8)) : 3'b0 c_DESCBYTEALIGNBITS = 4
67: logic [((W_MODULE_DESC + c_DESCBYTEALIGNBITS) - 1):0] s_in_desc; // Configuration bus from feeder modulelogic [((204 + 4) -1):0] s_in_des
logic [207:0] s_in_des
68: localparam c_IN_DESC_BYTE_CNT = ((W_MODULE_DESC + c_DESCBYTEALIGNBITS)/8);c_IN_DESC_BYTE_CNT = ((204 + 4)/8)
c_IN_DESC_BYTE_CNT = ((208)/8)
c_IN_DESC_BYTE_CNT = 26
69: localparam c_IN_DATA_BYTE_CNT = (W_MODULE_DATA/8);c_IN_DATA_BYTE_CNT = (16/8)
c_IN_DATA_BYTE_CNT = 2
70: localparam c_OUT_DATA_BYTE_CNT = (W_MCDMA_DATA/8);
c_OUT_DATA_BYTE_CNT = (256/8)
c_OUT_DATA_BYTE_CNT = 32
The lines 140 and 144 are in vector_capture.sv are:
140: for (int c = c_IN_DESC_BYTE_CNT; c < c_OUT_DATA_BYTE_CNT; c++)
(int c = 26; c < 32; c++)
c can take only 26, 27, 28, 29, 30 and 31
141: begin
142: if (c < (c_IN_DESC_BYTE_CNT + (c_IN_DATA_BYTE_CNT - s_in_empty)))(c < (26 + (2 - s_in_empty)))
(c < (28 - s_in_empty))
if s_in_empty is 0
c can take only 26 and 27
if s_in_empty is 1
c can take only 26
143: s_output_data[c] <= s_in_data[((W_MODULE_DATA - ((c - c_IN_DESC_BYTE_CNT) * 8)) - 1) -: 8];
If c become 26, the line becomes
s_output_data[26] <= s_in_data[((16 - ((26 - 26) * 8)) - 1) -: 8]
s_output_data[26] <= s_in_data[((16 - ((0) * 8)) - 1) -: 8]
s_output_data[26] <= s_in_data[((16 - 0 - 1) -: 8]
s_output_data[26] <= s_in_data[15 -: 8]
s_output_data[26] <= s_in_data[15 : 8]
If c become 27, the line becomes
s_output_data[27] <= s_in_data[((16 - ((27 - 26) * 8)) - 1) -: 8]
s_output_data[27] <= s_in_data[((16 - ((1) * 8)) - 1) -: 8]
s_output_data[27] <= s_in_data[((16 - 8 - 1) -: 8]
s_output_data[27] <= s_in_data[7 -: 8]
s_output_data[27] <= s_in_data[7 : 0]
144: end
From the above calculations, c cannot take any values that drives the index of s_in_data to be -8.
Ranesh
- Ranesh3 years ago
Hi Sheng,
What you are saying is correct, but it cannot be the cause of this error.
Lines 21, 26 and 27 of vector_capture_synth_top.sv are:
21: parameter W_MCDMA_DATA = 256;
Lines 66 to 70 of vector_capture.sv are:
> 0) ? (8 - (204 % 8)) : 3'b0 c_DESCBYTEALIGNBITS = (4 > 0) ? (8 - 4) : 3'b0
logic [((204 + 4) - 1):0] s_in_desc;
logic [207:0] s_in_desc;
Lines 140 to 144 of vector_capture.sv are:
Within this for loop, c can take only 26, 27, 28, 29, 30 and 31
141: begin
Note: s_in_empty is a single bit.
Within this if statement:
If s_in_empty = 0, (c < (28 - 0)) and c can be either 26 or 27
If s_in_empty = 1, (c < (28 - 1)) and c can be either 26
If c takes 26
s_output_data[26] <= s_in_data[((16 - ((26 - 26) * 8)) - 1) -: 8];
s_output_data[26] <= s_in_data[((16 - ((0) * 8)) - 1) -: 8];
s_output_data[26] <= s_in_data[((16 - (0) - 1) -: 8];
s_output_data[26] <= s_in_data[((16 - 1) -: 8];
s_output_data[26] <= s_in_data[15 -: 8];
s_output_data[26] <= s_in_data[15 : 8];
If c takes 27
s_output_data[26] <= s_in_data[((16 - ((27 - 26) * 8)) - 1) -: 8];
s_output_data[26] <= s_in_data[((16 - ((1) * 8)) - 1) -: 8];
s_output_data[26] <= s_in_data[((16 - (8) - 1) -: 8];
s_output_data[26] <= s_in_data[((8 - 1) -: 8];
s_output_data[26] <= s_in_data[7 -: 8];
s_output_data[26] <= s_in_data[7 : 0];
144: end
From the above calculations, c cannot take any values that drives index of s_in_data to be -8.
Ranesh
- Ranesh3 years ago
Hi Sheng,
141: begin
If c takes 26
If c takes 27
144: end
Ranesh
