matferronato
2 years agoAn illegal LCB was detected.
Hi, I created 4 partitions in my design, ran synthesis and place & route, and exported the final qdb. Then when I tried to reload the design and source the respective partition database, I get the ...
SyafieqS
2 years agoMost of the time internal error is related to tool issue (although there are cases it is not).
We need the design to root cause and provide workaround if possible otherwise it will be hard.
If you cant provide the design, a small test case that replicate the issue will be enough.
