@Brad : I did run the simulation for quite a lot of time but no change. Actually I'm simulating on Modelsim and here is the result I get :
http://img179.imageshack.us/img179/4843/pllaj9.jpg I do not assert areset because it makes error and it should not be a problem to lock the PLL.
The code is attached and is a simple PLL generated by Quartus II megafunction. The PLL is just supposed to output the same clock frequency as the input one.
As you can see, subwire1 and subwire0(0) has X values and I dont know why.
LIBRARY ieee;
USE ieee.std_logic_1164.all;
LIBRARY altera_mf;
USE altera_mf.all;
ENTITY pll IS
PORT
areset : IN STD_LOGIC := '0';
inclk0 : IN STD_LOGIC := '0';
c0 : OUT STD_LOGIC ;
locked : OUT STD_LOGIC
END pll;
ARCHITECTURE SYN OF pll IS
SIGNAL sub_wire0 : STD_LOGIC_VECTOR (5 DOWNTO 0);
SIGNAL sub_wire1 : STD_LOGIC ;
SIGNAL sub_wire2 : STD_LOGIC ;
SIGNAL sub_wire3 : STD_LOGIC ;
SIGNAL sub_wire4 : STD_LOGIC_VECTOR (1 DOWNTO 0);
SIGNAL sub_wire5_bv : BIT_VECTOR (0 DOWNTO 0);
SIGNAL sub_wire5 : STD_LOGIC_VECTOR (0 DOWNTO 0);
COMPONENT altpll
GENERIC (
clk0_divide_by : NATURAL;
clk0_duty_cycle : NATURAL;
clk0_multiply_by : NATURAL;
clk0_phase_shift : STRING;
compensate_clock : STRING;
gate_lock_signal : STRING;
inclk0_input_frequency : NATURAL;
intended_device_family : STRING;
invalid_lock_multiplier : NATURAL;
lpm_type : STRING;
operation_mode : STRING;
port_activeclock : STRING;
port_areset : STRING;
port_clkbad0 : STRING;
port_clkbad1 : STRING;
port_clkloss : STRING;
port_clkswitch : STRING;
port_configupdate : STRING;
port_fbin : STRING;
port_inclk0 : STRING;
port_inclk1 : STRING;
port_locked : STRING;
port_pfdena : STRING;
port_phasecounterselect : STRING;
port_phasedone : STRING;
port_phasestep : STRING;
port_phaseupdown : STRING;
port_pllena : STRING;
port_scanaclr : STRING;
port_scanclk : STRING;
port_scanclkena : STRING;
port_scandata : STRING;
port_scandataout : STRING;
port_scandone : STRING;
port_scanread : STRING;
port_scanwrite : STRING;
port_clk0 : STRING;
port_clk1 : STRING;
port_clk2 : STRING;
port_clk3 : STRING;
port_clk4 : STRING;
port_clk5 : STRING;
port_clkena0 : STRING;
port_clkena1 : STRING;
port_clkena2 : STRING;
port_clkena3 : STRING;
port_clkena4 : STRING;
port_clkena5 : STRING;
port_extclk0 : STRING;
port_extclk1 : STRING;
port_extclk2 : STRING;
port_extclk3 : STRING;
PORT (
inclk : IN STD_LOGIC_VECTOR (1 DOWNTO 0);
locked : OUT STD_LOGIC ;
areset : IN STD_LOGIC ;
clk : OUT STD_LOGIC_VECTOR (5 DOWNTO 0)
END COMPONENT;
BEGIN
sub_wire5_bv(0 DOWNTO 0) <= "0";
sub_wire5 <= To_stdlogicvector(sub_wire5_bv);
sub_wire1 <= sub_wire0(0);
c0 <= sub_wire1;
locked <= sub_wire2;
sub_wire3 <= inclk0;
sub_wire4 <= sub_wire5(0 DOWNTO 0) & sub_wire3;
altpll_component : altpll
GENERIC MAP (
clk0_divide_by => 1,
clk0_duty_cycle => 50,
clk0_multiply_by => 1,
clk0_phase_shift => "0",
compensate_clock => "CLK0",
gate_lock_signal => "NO",
inclk0_input_frequency => 10000,
intended_device_family => "Cyclone II",
invalid_lock_multiplier => 5,
lpm_type => "altpll",
operation_mode => "NORMAL",
port_activeclock => "PORT_UNUSED",
port_areset => "PORT_USED",
port_clkbad0 => "PORT_UNUSED",
port_clkbad1 => "PORT_UNUSED",
port_clkloss => "PORT_UNUSED",
port_clkswitch => "PORT_UNUSED",
port_configupdate => "PORT_UNUSED",
port_fbin => "PORT_UNUSED",
port_inclk0 => "PORT_USED",
port_inclk1 => "PORT_UNUSED",
port_locked => "PORT_USED",
port_pfdena => "PORT_UNUSED",
port_phasecounterselect => "PORT_UNUSED",
port_phasedone => "PORT_UNUSED",
port_phasestep => "PORT_UNUSED",
port_phaseupdown => "PORT_UNUSED",
port_pllena => "PORT_UNUSED",
port_scanaclr => "PORT_UNUSED",
port_scanclk => "PORT_UNUSED",
port_scanclkena => "PORT_UNUSED",
port_scandata => "PORT_UNUSED",
port_scandataout => "PORT_UNUSED",
port_scandone => "PORT_UNUSED",
port_scanread => "PORT_UNUSED",
port_scanwrite => "PORT_UNUSED",
port_clk0 => "PORT_USED",
port_clk1 => "PORT_UNUSED",
port_clk2 => "PORT_UNUSED",
port_clk3 => "PORT_UNUSED",
port_clk4 => "PORT_UNUSED",
port_clk5 => "PORT_UNUSED",
port_clkena0 => "PORT_UNUSED",
port_clkena1 => "PORT_UNUSED",
port_clkena2 => "PORT_UNUSED",
port_clkena3 => "PORT_UNUSED",
port_clkena4 => "PORT_UNUSED",
port_clkena5 => "PORT_UNUSED",
port_extclk0 => "PORT_UNUSED",
port_extclk1 => "PORT_UNUSED",
port_extclk2 => "PORT_UNUSED",
port_extclk3 => "PORT_UNUSED",
valid_lock_multiplier => 1
PORT MAP (
inclk => sub_wire4,
areset => areset,
clk => sub_wire0,
locked => sub_wire2
END SYN;
@Avatar : I dont get what you mean but I tried and nothing changes.
