11 years ago
altmult_add
i have two questions:
1- how the altmult_add megafunction can be used in a pipelined structure?
2- which method is the best to calculate inner product of two vectors, having 3 elements, in a pipelined structure:a altmult_add with 3 input or 2 lpmmult mfs and 2 lpmadd_sub mfs?
Bedri
    1. It is already pipelined.
    2. Im not quite sure what you mean? do you mean 2 vectors with 3 elemenents in each:
    sum(
    a(0) * b(0)
    a(1) * b(1)
    a(2) * b(2)
    In this case you need 3 multipliers and 2 adders.
    I would suggest the altmult_add will probably work better than a custom made pipeline, if it suits your purpose. Why not simulate them and find out?
    Thank you for your reply.
    --- Quote Start ---
    sum(
    a(0) * b(0)
    a(1) * b(1)
    a(2) * b(2)
    --- Quote End ---
    i did mistake and yes you are right that i need 3 multipliers.
    --- Quote Start ---
    I would suggest the altmult_add will probably work better than a custom made pipeline, if it suits your purpose.out?
    --- Quote End ---
    Thank you for suggestion.
    --- Quote Start ---
    --- Quote End ---
    I'm a beginner. Sometimes my simulation results may be different real works on DE2-115 board. Nevertheless i have trying to simulate.
    Well, i have implemented my calculations in pipelined structures and i think that this type implementations need latencies of the pipelined blocks. i have searched to find whether altmult_add megafunction has a latency or output ready signal?
    if i have to calculate the equation below how can i detect that the output of the altmult_add is ready for adder which will add the output of the altmult_add to 5?
    sum(
    a(0) * b(0)
    a(1) * b(1)
    a(2) * b(2)
    ) + 5;
    Bedri
    --- Quote Start ---
    sum(
    a(0) * b(0)
    a(1) * b(1)
    a(2) * b(2)
    ) + 5;
    Bedri
    --- Quote End ---
    you need one mult (inputs a,b). accumulate results over 3 samples adding 5 as well. latency issues can be seen in simulation.
