Thank you for your reply.
--- Quote Start ---
1. It is already pipelined.
2. Im not quite sure what you mean? do you mean 2 vectors with 3 elemenents in each:
sum(
a(0) * b(0)
a(1) * b(1)
a(2) * b(2)
In this case you need 3 multipliers and 2 adders.
--- Quote End ---
i did mistake and yes you are right that i need 3 multipliers.
--- Quote Start ---
I would suggest the altmult_add will probably work better than a custom made pipeline, if it suits your purpose.out?
--- Quote End ---
Thank you for suggestion.
--- Quote Start ---
Why not simulate them and find
--- Quote End ---
I'm a beginner. Sometimes my simulation results may be different real works on DE2-115 board. Nevertheless i have trying to simulate.
Well, i have implemented my calculations in pipelined structures and i think that this type implementations need latencies of the pipelined blocks. i have searched to find whether altmult_add megafunction has a latency or output ready signal?
if i have to calculate the equation below how can i detect that the output of the altmult_add is ready for adder which will add the output of the altmult_add to 5?
sum(
a(0) * b(0)
a(1) * b(1)
a(2) * b(2)
) + 5;
Bedri
