displayname6
2 years agoAltera Quatus Ⅱ
Can I use "Altera Quatus II" with Azure AVD? Is the software supported? Or can I use it but not support it? Is this the right place to post?
- 2 years ago
In term of license, as long as you have a valid Quartus Pro/Standard license, you should be able to run the Quartus II software subscription version.
Quartus II Web Edition is free and does not require license.
You can test it out on the non-supported platform but you will have to bear your own risk and there will be no technical support as well.
Richard Tan
RichardT_altera
2 years agoIn term of license, as long as you have a valid Quartus Pro/Standard license, you should be able to run the Quartus II software subscription version.
Richard Tan
