11 years agoAltera monitor program terminal device problem
Hi guys,
I have some troubles with the Altera Monitor Program. As I write in the title, when I create a new project, I select all the needed parameters and then, when I am on the "Specify system parameters" table, the Terminal device drop-down menu can't see the device and it show me " <none> " and I can't select any other things... Someone can help me ? I use the DE2 board with the latest version that support Cyclone II (Quartus 13.0sp1 and Altera Monitor Program 13.0) on a windows 7 64Bits machine. Thank you, Regards.
