16 years ago
Altera Monitor Program compilation failed!
hi, guys, the error info is as follows:
/usr/bin/bash: e:/program: No such file or directory
/usr/bin/bash: nios2-elf-ld: command not found
Compilation stopped.
what's goin on? Nearly desperate, the tutorial is not helpful at all! or may be the tutorial is too old version.
thanks, guys
    --- Quote Start ---
    Hi grit,
    did you first download your Nios hardware (.sof file) in the FPGA before starting the Altera Monitor Program?
    --- Quote End ---
    Hi, Sanmao,
    The error msg has gone now. I guess it is because previously I clicked cancel on the window of "open core plus time: unlimited".
    Anyway, this error is gone already. However, a new problem just came, the lights.c is loaded into the cyclone II, but when I execute it using the Altera Monitor program, the LEDs didn't turn on when I toggled the switches...there is no error message occured during the execution either...
    What problem could it be this time?
    Thanks and regards
    When I am trying to compile and load the getting_started_s program in University program, I am getting following error:
    nios2-elf-objcopy -O srec E:/altera/91/University_Program/NiosII_Computer_Systems/DE2/DE2_Basic_Computer/app_software/getting_started_s/getting_started.elf E:/altera/91/University_Program/NiosII_Computer_Systems/DE2/DE2_Basic_Computer/app_software/getting_started_s/getting_started.srec
    /usr/bin/bash: line 0: igncr: invalid option name
    I have reinstalled whole altera but still its giving the same error.
    I am trying to do following Tutorial:
    Using the SDRAM on Altera’s DE2-115 Board with VHDL Designs.
    This tutorial uses Altera Monitor Program software as application program.
    While compiling and loading in Altera Monitor Program, I am getting following similar error:
    I tried the solutions discussed above in this thread but can't remove error.
    Any help?
    Thanks in advance
