13 years agoHello,
I am trying to do following Tutorial: Using the SDRAM on Altera’s DE2-115 Board with VHDL Designs. This tutorial uses Altera Monitor Program software as application program. While compiling and loading in Altera Monitor Program, I am getting following similar error: /usr/bin/bash: nios2-elf-ld: command not found Compilation stopped. I tried the solutions discussed above in this thread but can't remove error. Any help? Thanks in advance
