--- Quote Start --- Hi grit, did you first download your Nios hardware (.sof file) in the FPGA before starting the Altera Monitor Program? --- Quote End --- Hi, Sanmao, The error msg has gone now. I guess it is because previously I clicked cancel on the window of "open core plus time: unlimited". Anyway, this error is gone already. However, a new problem just came, the lights.c is loaded into the cyclone II, but when I execute it using the Altera Monitor program, the LEDs didn't turn on when I toggled the switches...there is no error message occured during the execution either... What problem could it be this time? Thanks and regards - Altera_Forum
When I am trying to compile and load the getting_started_s program in University program, I am getting following error:
nios2-elf-objcopy -O srec E:/altera/91/University_Program/NiosII_Computer_Systems/DE2/DE2_Basic_Computer/app_software/getting_started_s/getting_started.elf E:/altera/91/University_Program/NiosII_Computer_Systems/DE2/DE2_Basic_Computer/app_software/getting_started_s/getting_started.srec /usr/bin/bash: line 0: igncr: invalid option name I have reinstalled whole altera but still its giving the same error. - Altera_Forum
I am trying to do following Tutorial: Using the SDRAM on Altera’s DE2-115 Board with VHDL Designs. This tutorial uses Altera Monitor Program software as application program. While compiling and loading in Altera Monitor Program, I am getting following similar error: /usr/bin/bash: nios2-elf-ld: command not found Compilation stopped. I tried the solutions discussed above in this thread but can't remove error. Any help? Thanks in advance
