Altera cyclone 2 programming Via usb blaster
- Hello FvM,first of all thanks for your attention.There is an Altera EPCS1N Eprom next to cyclone 2,do you think, that might be the memory keeping the configuration?Also we dont know,which device and software to use for connection and how to make connections l,can you help on this?
- FvM
Cyclone 2 has no internal configuration memory. Need to determine which memory device holds the configuration and how it can be interfaced with programmer, also if Cyclone 2 is accessible by JTAG. E.g. EPCS serial flash can be read-out through JTAG.
- Veyseltuylu
- FvM
Most certainly EPCS1 is the configuration memory. If the board has a standard 10-pin JTAG or active serial programming connector, the memory can be readout with Quartus standalone programming software and USB-Blaster or compatible programming adapter.
- NurAiman_M_Intel
Any update for this case?
Aiman
- NurAiman_M_Intel
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
