Veyseltuylu
3 years agoAltera cyclone 2 programming Via usb blaster
Hello, we have a an electronic print used altera cyclone 2 ep2c5t144c8n on, we need to upload the programme included and download this programme to another altera cyclone 2 processor,can you help on t...
- 3 years agoHello FvM,first of all thanks for your attention.There is an Altera EPCS1N Eprom next to cyclone 2,do you think, that might be the memory keeping the configuration?Also we dont know,which device and software to use for connection and how to make connections l,can you help on this?
FvM
3 years agoMost certainly EPCS1 is the configuration memory. If the board has a standard 10-pin JTAG or active serial programming connector, the memory can be readout with Quartus standalone programming software and USB-Blaster or compatible programming adapter.
