Charlesa
2 years agoaltera_connection_identification_hub error
Hi, During compilation of a design in Quartus Prime 17.0, I get following error, Warning (12019): Can't analyze file -- file db/ip/slde4bbd51f/altera_connection_identification_hub_170/synth/alt_sl...
- 2 years ago
Two things: 1) What debugging tool are you using that is adding in the sld hub? Signal Tap? 2) There are spaces in your project path. That could be the problem.
TingJiangT_Intel
Contributor
2 years agoIs your project upgraded from an old version?
And please check if your full path is correct (without characters not allowed).
- Charlesa2 years ago
Thank you. Fixing the path, fixed the problem.
