12 years agoaltera_attribute not working.
Hi All,
I want to cut the timing path between two nodes.I used altera_attribute in my verilog design file to cut the path between asynchronous nodes. From the timing report,its look like that this attribute is ignored and I am getting the set up violation. If I am applying same constraint in the sdc file,its working and I am not getting any set up time violation. I have attached the design. Thanks in advance, Krupesh.
