11 years ago# ALTASMI_PARALLEL.
# Create clock for ALTASMI_PARALLEL constraints.
create_generated_clock
-name asmi_dclk
-source }]
From what I can see from the technology map viewer the 'dclk' pin is named 'flash_ctrl:flash_ctrl0|flash_if:flash_if0|flash_if_altasmi_parallel_f182:flash_if_altasmi_parallel_f182_component|cycloneii_asmiblock2~ALTERA_DCLK'.
