11 years ago --- Quote Start --- I'm not sure what you mean by 'add it as separate clk statement in sdc'. The derive_generated_clocks command produces the PLL clock and then I used a create_generated_clock for the DCLK pin. I was basing this on user dwh's 'TimeQuest Quad-SPI Flash Constraints Analysis' report. Edit: That should be 'derive_pll_clocks command' --- Quote End --- where is your statement for dclk pin as a generated clk The one above does not seem to refer to the dclk pin.
