11 years agoI'm not sure what you mean by 'add it as separate clk statement in sdc'. The derive_generated_clocks command produces the PLL clock and then I used a create_generated_clock for the DCLK pin. I was basing this on user dwh's 'TimeQuest Quad-SPI Flash Constraints Analysis' report.
Edit: That should be 'derive_pll_clocks command'
