agieson_cl
1 year agoALT_EXCEPTION_STACK macro does not create exception_stack memory region
Hi! I'm using Quartus Standard Prime 23.1.1 to upgrade a NiosII C10LP design to NiosV and I'm having trouble with the BSP / Linker. From the description of the hal.linker.enable_exception_stack op...
KianHinT_altera
1 year agoHi
Apologies for the delay in getting back as was tied up with issue backlog, may I know whether the issue been resolved on your end?
For the linker exception , I saw there is some restriction mentioned at NiosV guide
Just make sure to adhere to the restriction condition mentioned in the link above. Is there an issue or error that you're facing when migrating to Nios V design?
Kian
