amartinez
1 year agoAgilex-9 DSP Builder
Hello, I am trying to use DSP builder to generate a demo FFT, but the Device block doesn't let me select Agilex-9. Is that supposed to be an option or should I use an Agilex-7 instead? I am using ...
amartinez
1 year agoHello CheePin and Edward,
putting the Quartus.ini file in $QUARTUS_ROOTDIR worked and I am now able to see the Agilex-9 in DSP builder. thank you both so much for the help with this issue!
-Andres
