amartinez
1 year agoAgilex-9 DSP Builder
Hello, I am trying to use DSP builder to generate a demo FFT, but the Device block doesn't let me select Agilex-9. Is that supposed to be an option or should I use an Agilex-7 instead? I am using ...
CheepinC_altera
1 year agoHi Andres,
Just to share—I've tested the method of placing the quartus.ini file directly in the same project folder where I launch Quartus and DSP Builder. With this setup, I was able to see the Agilex 9 device available in the selection list. This aligns with one of the approaches Edward recommended earlier.
You might want to give this method a try and see if it works on your end as well.
Let me know if you have any concerns or need further assistance. Thank you!
