fpgator
1 year agoAgilex 7 DevKit | OSFP Board Test System | Transceiver Toolkit Error
Tried Quartus 25.1 and older versions. I have loaded the OSFP example, and the Board Test System (BTS) GUI is working fine. When I go to Quartus and I want to use the Transceiver Toolkit, the Toolk...
Ash_R_Altera
1 year agoHi,
Are you using the example design provided in the dev kit installer package? If yes, I am not sure if it was enabled for the toolkit also or not.
Normally this type of error would occur if the AVMM interface is unconnected to JTAG master. Check the IP settings in Quartus and see if "Enable Debug Endpoint..." options are checked or not.
Design is available in the examples folder of the installer.
fpgator
1 year agoIndeed they were not checked. However, when I checked them, I was also not able to connect using the transceiver toolkit. Is there any other setting I need to change?
Also, how is the BTS GUI reading and writing into the transceivers (BER, FFE, etc)? I presume it uses AvaIon interface. Is there a sample code to see how to connect read and write to the transceivers?
