robertzab's avatar
robertzab
11 days ago
Agilex 5 – Critical HSSI Error in JESD204B Example Design
I am bringing up the JESD204B interface on the dev kit.
For this, I used the "Generate Example Design" option with the following parameters:
When I generate the project and start synthesis, it reaches the "HSSI Support Logic Generation" stage, and Quartus reports the following critical error:
It turns out that the generated file
contains an inconsistency in the generated HSSI metadata.
My fix was to replace the entry in:
The problem is that after updating the Qsys file, it gets changed back to intel_jesd_RX, and HSSI reports the critical error again.
If there is already a fix or workaround for this issue, please let me know.
For now, I added a simple script that I run from PowerShell:
that replaces this value with the correct one:
1 Reply
  • Could you try in the latest Quartus Pro version 26.1 (released publicly last week on 7th Apr) and see if the issue still persists?
    If the issue persists, please share the QAR file (In Quartus, go to ProjectArchive Project) as a .zip file. Unfortunately, the forum does not support direct .qar file attachments.
    Richard Tan
