maya123
1 year agoAfter synthesis, I can't see the state diagrams in state machine viewer
Hi, everyone! I'm using the OSPI protocol to transfer data from Cyclone IV to STM32. I designed a state machine with three states, and a piece of breathing light code that identifies the normal ope...
FvM
1 year agoHi,
problem with above posted code is that signal STATE is a combinational latch, not a clocked register.
Need to add clock edge sensitive condidtion, e.g.
PROCESS(clk,OSPI_NCS)
BEGIN
if rising_edge(clk) then
CASE STATE IS
WHEN IDLE =>
IF (OSPI_NCS = '0') THEN
STATE <= DATA_PREPARE;
ELSE
STATE <= IDLE;
END IF;
WHEN DATA_PREPARE =>
OSPI_IO_TEMP <= SEND_DATA;
DRDY <= '1'; --- data_ready ---
STATE <= DATA_TRANSMIT;
WHEN DATA_TRANSMIT =>
IF(DRDY = '1' AND BYTE_COUNTER = 1) THEN
STATE <= IDLE;
ELSE
END IF;
WHEN OTHERS =>
STATE <= IDLE;
END CASE;
end if;
END PROCESS;
