13 years ago
Additional circuit within a circuit - if then else
I am a beginner to VHDL and currently have an assignment to complete. It is as follows:
  • A digital circuit has two 4-bit inputs a
I have written the architecture correct for the subtractor part. This fully compiles. When I try to write the subcircuit for the If Then Else part about the 'the circuit has a single bit output t that is to be high if the result of the subtraction is zero' part I struggle.
This is my code so far
entity ComparatorSubtractor4Bit is port (
a,b : in integer range 0 to 15;
borrowin : in integer range 0 to 1;
sub : out integer range 0 to 15;
t : out integer range 0 to 1);
end ComparatorSubtractor4Bit;
architecture Adder of ComparatorSubtractor4Bit is
begin
sub<= a - b - borrowin; -- note borrow out will be sub[4]
process (a,b)
begin
if sub<= 0 then t<=1;
else t<=0;
end if;
end process;
end Adder;
I have written a sub If Then Else code on a previous assignment which involved the inputs being compared, however it seems to have a problem when I try to If Then Else the output.
Any help would be greatly appreciated
Sam
    Thje error message seems self-explanatory to me, isn't it?
    --- Quote Start ---
    Error (10309): VHDL Interface Declaration error in test.vhd(17): interface object "sub" of mode out cannot be read. Change object mode to buffer.
    --- Quote End ---
    --- Quote Start ---
    --- Quote End ---
    No, I don't really know what the error messages mean. Like I say I'm just a beginner. Could you explain further?
    You cannot read (eg. check the value of) an output port. Either create a temporary internal signal or change the mode from "out" to "buffer".
    sub : buffer integer range 0 to 15;
