10 years agoAdd vhdl records as pin-assignments
Is it possible to create a design which his input/output ports are VHDL records and to make synthesizable and programmable?
Let's say I have a package I wrote and in it I define a record type:
package lib is
type bla is record
x:std_logic;
y:std_logic_vector(3 downto 0);
end record;
end package;
and I have the following design file:
use work.lib.all;
entity hello is
port(
world:in bla;
output:out std_logic
end entity;
From what I know, what I wrote is synthesizable but If I try to create a symbol file I get an error that it's not possible in the current version of Quartus or something like that.. therefor I have 2 questions: 1. Is it possible to create a symbol file (to put in a block-diagram-file) from such a design file like in my example? 2. Is it possible to create a project with pure VHDL and without *.BDF files and tell Quartus to that the pin-assignments for the record are something like that: world.x is assigned to pin_* (whatever) and world.y is assigned to a pin_* etc...1 Reply
1. Records and schematics don't mix. So no.
2. I think it will work, but usually it's recommended to stick to non record types at the top level, and types that all map to bits (so no integers). But records internally is a good idea.
