13 years agoActual system ID not found on target at base address
Hi, guys
I am using SOPC to build an NiosII system. when i download my elf file to EPCS, I got two error message like that"Actual system id is not found on target at base address" , "Actual system timestamp not found on target at base address". In my surprising, Another NiosII system for other project can work well and there is no difference between this two NiosII components. I don't know what was happened. It block me several days, hope you can give me more guide and work out it. more detail in the progress had been attached . Thanks! My PCB board system is good I have added the system id component and it connect to CPU. data master
