12 years agoAccessing SDRAM memory on Terasic DE0-Nano board.
I want to use SDRAM memory located on DE0-Nano board using Verilog (without using Nios).
I use http://www.altera.com/support/examples/nios2/exm-avalon-mm.html System placed in the QSYS: https://www.alteraforum.com/forum/attachment.php?attachmentid=8357 sdram_write not currently used. Code://=======================================================
module SRAM(
CLOCK_50, LED,
DRAM_ADDR, DRAM_BA, DRAM_CAS_N, DRAM_CKE, DRAM_CLK, DRAM_CS_N, DRAM_DQ, DRAM_DQM, DRAM_RAS_N, DRAM_WE_N //Memory pin
//////////// CLOCK //////////
input CLOCK_50;
//////////// LED //////////
output LED;
//reg LED;
//////////// SDRAM //////////
output DRAM_ADDR;
output DRAM_BA;
output DRAM_CAS_N;
output DRAM_CKE;
output DRAM_CLK;
output DRAM_CS_N;
inout DRAM_DQ;
output DRAM_DQM;
output DRAM_RAS_N;
output DRAM_WE_N;
//////////// AVALON MASTER TEMPLATE //////////
wire qsys_sdram_read_control_fixed_location;
wire qsys_sdram_read_control_read_base;
wire qsys_sdram_read_control_read_length;
wire qsys_sdram_read_control_go;
reg reg_qsys_sdram_read_control_fixed_location;
reg reg_qsys_sdram_read_control_read_base;
reg reg_qsys_sdram_read_control_read_length;
reg reg_qsys_sdram_read_control_go;
wire qsys_sdram_read_control_done;
wire qsys_sdram_read_control_early_done;
wire qsys_sdram_read_user_read_buffer;
reg reg_qsys_sdram_read_user_read_buffer;
wire qsys_sdram_read_user_buffer_output_data;
wire qsys_sdram_read_user_data_available;
reg gooff=0;
reg rboff=0;
reg init=1;
qsys u0(
.clk_clk(CLOCK_50), //clk.clk
.reset_reset_n(1'b1), //reset.reset_n
.sdram_clock_c0_clk(DRAM_CLK), //sdram_clock_c0.clk
.sdram_clock_areset_conduit_export(1'b0), //sdram_clock_areset_conduit.export
.sdram_wire_addr(DRAM_ADDR), //sdram_wire.addr
.sdram_wire_ba(DRAM_BA), // .ba
.sdram_wire_cas_n(DRAM_CAS_N), // .cas_n
.sdram_wire_cke(DRAM_CKE), // .cke
.sdram_wire_cs_n(DRAM_CS_N), // .cs_n
.sdram_wire_dq(DRAM_DQ), // .dq
.sdram_wire_dqm(DRAM_DQM), // .dqm
.sdram_wire_ras_n(DRAM_RAS_N), // .ras_n
.sdram_wire_we_n(DRAM_WE_N), // .we_n
.sdram_read_control_fixed_location(qsys_sdram_read_control_fixed_location),
.sdram_read_control_read_base(qsys_sdram_read_control_read_base),
.sdram_read_control_read_length(qsys_sdram_read_control_read_length),
.sdram_read_control_go(qsys_sdram_read_control_go),
.sdram_read_control_done(qsys_sdram_read_control_done),
.sdram_read_control_early_done(qsys_sdram_read_control_early_done),
.sdram_read_user_read_buffer(qsys_sdram_read_user_read_buffer),
.sdram_read_user_buffer_output_data(qsys_sdram_read_user_buffer_output_data),
.sdram_read_user_data_available(qsys_sdram_read_user_data_available)
assign qsys_sdram_read_control_fixed_location = reg_qsys_sdram_read_control_fixed_location;
assign qsys_sdram_read_control_read_base = reg_qsys_sdram_read_control_read_base ;
assign qsys_sdram_read_control_read_length = reg_qsys_sdram_read_control_read_length ;
assign qsys_sdram_read_control_go = reg_qsys_sdram_read_control_go;
assign qsys_sdram_read_user_read_buffer = reg_qsys_sdram_read_user_read_buffer;
always @(posedge CLOCK_50)
begin
if (gooff)
begin
gooff <= 0;
reg_qsys_sdram_read_control_go <= 0;
end
if (init)
begin
reg_qsys_sdram_read_control_fixed_location <= 0;
reg_qsys_sdram_read_control_read_base <= 0;
reg_qsys_sdram_read_control_read_length <= 8;
reg_qsys_sdram_read_control_go <= 1;
gooff <= 1;
init <= 0;
end
end
assign LED = qsys_sdram_read_user_buffer_output_data ;
endmodule
Memory is not written so it should read garbage and display on the LEDs, but the LEDs do not light.16 Replies
I want to write SDRAM through my custom hardware IP. I am using the Master Templates for this. I am writing using custom hardware and reading using NIOS, but my bios doesn't read the correct value. Below is my code for writing into SDRAM. I want to write on the click of a button (coe_switch[3]). I have one more doubt, "myBuffer_control_write_write_base" should be the base address for SDRAM or offset or base+offest. reg searchForSync; always @(posedge csi_clk or negedge rsi_rst) begin if(!rsi_rst) begin click <= 0; searchForSync <= 0; end else begin if(coe_switch[3] == 0) begin searchForSync <= 1; myBuffer_control_write_fixed_location <= 0; myBuffer_control_write_write_base <= 32'h00000000; myBuffer_control_write_write_length <= 8; myBuffer_control_write_go <= 1; myBuffer_user_write_buffer_input_data <= 1; myBuffer_user_write_write_buffer <= 1; end if(searchForSync == 1) begin myBuffer_user_write_buffer_input_data <= 1; myBuffer_user_write_write_buffer <= 1; myBuffer_control_write_go <= 0; if(asi_stin_sop_reg[319] == 1) begin end end end end Please let me know if I am doing something wrong. Please suggest. - Altera_Forum
--- Quote Start --- Problem fixed. Need to wait two clock tacts before reading. --- Quote End --- Hello, Did you tried writing into SDRAM. I am trying but couldn't get the result. Please check my post on the same thread. Thanks - Altera_Forum
Someone please suggest on the issue.
Post your problem in a new thread. Then more people will see it, not just those subscribed to this thread :).
Tip: please post more detail then you already have. The information you've posted isn't really enough. E.g. what does the code for your 'custom hardware IP' look like? Please wrap any code posted with code tags... Regards, Alex - Altera_Forum
Dear Mikel7,
I would use a on Deo Nano board the SDRAM without using the Nios || processor, could you share your working code for SDRAM? Thanks in advances, Alexgiul - Altera_Forum
I'am not used this board for long time, but this should work:
//======================================================= module SRAM( CLOCK_50, LED, KEY, DRAM_ADDR, DRAM_BA, DRAM_CAS_N, DRAM_CKE, DRAM_CLK, DRAM_CS_N, DRAM_DQ, DRAM_DQM, DRAM_RAS_N, DRAM_WE_N //Memory pin ); //////////// CLOCK ////////// input CLOCK_50; //////////// LED ////////// output LED; reg LED; //////////// KEY ////////// input KEY; //////////// SDRAM ////////// output DRAM_ADDR; output DRAM_BA; output DRAM_CAS_N; output DRAM_CKE; output DRAM_CLK; output DRAM_CS_N; inout DRAM_DQ; output DRAM_DQM; output DRAM_RAS_N; output DRAM_WE_N; //////////// AVALON CONNECTOR ////////// wire qsys_sdram_read_control_fixed_location; wire qsys_sdram_read_control_read_base; wire qsys_sdram_read_control_read_length; wire qsys_sdram_read_control_go; reg reg_qsys_sdram_read_control_fixed_location; reg reg_qsys_sdram_read_control_read_base; reg reg_qsys_sdram_read_control_read_length; reg reg_qsys_sdram_read_control_go; wire qsys_sdram_read_control_done; wire qsys_sdram_read_control_early_done; wire qsys_sdram_read_user_read_buffer; reg reg_qsys_sdram_read_user_read_buffer; wire qsys_sdram_read_user_buffer_output_data; wire qsys_sdram_read_user_data_available; reg gooff=0; integer start=3; qsys u0( .clk_clk(CLOCK_50), //clk.clk .reset_reset_n(1'b1), //reset.reset_n .sdram_clock_c0_clk(DRAM_CLK), //sdram_clock_c0.clk .sdram_clock_areset_conduit_export(1'b0), //sdram_clock_areset_conduit.export .sdram_wire_addr(DRAM_ADDR), //sdram_wire.addr .sdram_wire_ba(DRAM_BA), // .ba .sdram_wire_cas_n(DRAM_CAS_N), // .cas_n .sdram_wire_cke(DRAM_CKE), // .cke .sdram_wire_cs_n(DRAM_CS_N), // .cs_n .sdram_wire_dq(DRAM_DQ), // .dq .sdram_wire_dqm(DRAM_DQM), // .dqm .sdram_wire_ras_n(DRAM_RAS_N), // .ras_n .sdram_wire_we_n(DRAM_WE_N), // .we_n .sdram_read_control_fixed_location(qsys_sdram_read_control_fixed_location), .sdram_read_control_read_base(qsys_sdram_read_control_read_base), .sdram_read_control_read_length(qsys_sdram_read_control_read_length), .sdram_read_control_go(qsys_sdram_read_control_go), .sdram_read_control_done(qsys_sdram_read_control_done), .sdram_read_control_early_done(qsys_sdram_read_control_early_done), .sdram_read_user_read_buffer(qsys_sdram_read_user_read_buffer), .sdram_read_user_buffer_output_data(qsys_sdram_read_user_buffer_output_data), .sdram_read_user_data_available(qsys_sdram_read_user_data_available) ); assign qsys_sdram_read_control_fixed_location = reg_qsys_sdram_read_control_fixed_location; assign qsys_sdram_read_control_read_base = reg_qsys_sdram_read_control_read_base ; assign qsys_sdram_read_control_read_length = reg_qsys_sdram_read_control_read_length ; assign qsys_sdram_read_control_go = reg_qsys_sdram_read_control_go; assign qsys_sdram_read_user_read_buffer = reg_qsys_sdram_read_user_read_buffer; always @(posedge CLOCK_50) begin if (start==1) begin reg_qsys_sdram_read_control_fixed_location <= 0; reg_qsys_sdram_read_control_read_base <= 0; reg_qsys_sdram_read_control_read_length <= 2; reg_qsys_sdram_read_control_go <= 1; gooff <= 1; end if (gooff) begin gooff <= 0; reg_qsys_sdram_read_control_go <= 0; end if (start) start = start - 1; LED <= qsys_sdram_read_user_buffer_output_data ; end endmodule
